Set View Matrix
IJSSEL
What I want to achieve  is having a Pop up node in the IP which gives me 4 choices : 2D/Plan, Front, Right Iso, Left Iso.
I was trying to find out if the Set View Matrix node would do the trick but don't know ( so far) if this is the way to go.
Any help appreciated 😊
  • Marionette Maven
So, I looked into this today and unfortunately at one point we introduced a method behind-the-scenes to fix a bug in Marionette Objects (they weren't always drawing correctly when in a 3D view) that saves and restores the current view after a Marionette network is run.
Because of this, unfortunately there's no way to set a view using a Marionette network.
I put in a request to look for an alternative method to solve the Marionette Object issue which will directly fix this issue and I'll try my best to let you know if and when that happens 🙂
  • 1 year later...
Hey Marissa
Is this node avayable? I would like to put an object node to an specific point in the file, but it only works in 2D-View. If I'm in a 3D View it moves it always like "relative". So I would like to set to Plan View an restore the view that was before. Sounds like the thing you were explaning...
