Prolyte PRT is red
@SCParker
This is a strange problem. Concern only Prolyte Touring Truss. I thing Cross Section is broken. If I change cross section to other manufacture. I have no problem.
I have clean VW. I use blank file for test it. I have all classes on. I use VW SP3 PC Won 10 Pro.
If I use blank file, calculate dialog box do not show any errors but on pdf raport some Tube workload are red and have no value.
If I use old file where i find this bug, calculate report show errors and raport show Tube workload at 300%
I do not Braceworks expert but Why this problem is only on Prolyte Touring Truss?
Coul you try replicate my proble on yours machine?
Edited by Robert Janiak
@Rob Books When I am in the office, I will send it, but you can do simple test.
Create blank file
Add 3xProlyte S36PRF-L305
Add 2xHoist
Calculate should be ok
Select All (Ctrl+A)
Rotate tool about 15 deg
Calculate should be wrong
I tested it on two different PC and get the same wrong result with S36PRF-L305 only.
