It would be nice if Vectorworks could have an equivalent of the "quad cursor" in BricsCAD.
For those not familiar with that, it is a pop-up window that automatically comes up when hovering over an object (selected or not) showing the most common commands/operations for such an object so that you are just one or two clicks away from the commands/operations. If there are more than 4 command/operation options you can click on them to see additional commands/operations of the same category (e.g. 3D modeling or annotations/dimensions, 2D editing etc.). It even "learns" which command/operation you usually choose in a category so after a few times it will show that one first and then the other options. It can improve efficiency quite a bit when implemented/used properly, especially if you can customize it with commands/operations like in their quad cursor.
A video of this (from 2013) that gives a good basic idea of it: BricsCAD Quad Cursor
Art V
It has been expanded/improved over the years
1 answer to this question
