Is it a known issue that invoking the Multi-view within annotation space causes the viewport under edit to be destroyed?
Generally to make it happen M-key pressed while the mouse is away from the bottom corner is another view is considered active. So pressing M key again cause a move to an unrelated view. Navigation by any means other than undo causes the viewport to be destroyed.
