Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Kristin Proeger
Door Types on Door Schedule
I am putting together a door schedule for the first time using Vectorworks. I am accustomed to assigning door types to each door, but I can't seem to figure out how to do this in Vectorworks. Does anyone know how to do this? Thanks!
In a Report/Schedule, every column must be linked to a formula or record.field combination. You can't just randomly type things into a column.
If you have a column with a record.field combination, you can type into the worksheet and edit that data.
You can use one of the fields from the Data pane of the Door object to act the the location to hold this data.
=Door.'UserFld1' would use User Field 1 to store the data.
Ask again if you need more help.
This was very helpful. I am not sure that I totally understand what you are saying, but I went into the Accessories Field, renamed it Door Type, and then was able to type in a letter for each door to indicate door type. Thanks!
