Patricia Angelu
SITE MODEL NOT WORKING
Hello, how do I get the rendering or the fill mode to the site model? I did follow everything else and was able to make a 3d but when I used every texture, all I get are the lines and not the actual textures. I'm not really used to this but please refer to screenshots. Also, how do I design on my 3d model? it automatically sits on the plane area and not on the terrain (model). I wanted to create site modifiers (pad and grade limits) but it doesn't really work. Please help me. It's my nth time stuck on repeat, no progress at all.
Hi
Not sure but it looks like you are in wirefram mode, try chosing openGL under the the teapot in your upper right corner
Hello! Thank you so much. It actually worked. I'm so happy because I've been stressing about it the whole night and now  88917045_ScreenShot2019-01-10at9_34_39PM.thumb.png.3974a95330ef5586d6722cab34e117fc.pngI get to move on with my school project. You are a genius!
Great to hear.
About the roads you must do them as filled polygons and right click on them and choose " create object from shape" then choose site modifier - texture bed" when all is done you will have to update the site model to get them to show on the sloped surface
texture bed site modifier for roads is another option and the roads from the polygon tool palette is also okay right? I will try both but I like how the roads calculate the stationing points. I guess I'll have to use texture bed for sidewalk and center islands then. I'll let you know how it ends haha but thank you again mr. Hans!
Hello good day! More queries again, still the same for site modifiers. I can't seem to draw on the surface of the terrain. I already tried "Send to Surface" but none. Also, I am working on a 70ha school project and of course there is slow performance because of my laptop but is there a better way to design on the site model in cropped plans so it would be easier and faster?
and basically right now, I am drawing on the site model instead of a new layer.
Lastly, I ended up drawing on 2d first before the site model because as of now, I'm already behind schedule and I think autocad will be easier for me but I don't want to go back and forth between the two softwares which is why I am trying to do everything in VW. What im trying to do, is it better though? - Drawings first before site model? I'm sorry for all the fuss and my confused brain here is also trying to catch up. I'm really interested on how far I could get with VW until Feb this year. I have so many questions and there's not a lot of students and professors from where I am whom I can ask about the workflows, basically starting from scratch atleast to the site model. The planting plan is one other thing. I hope you'll be patient with me. God bless.
Lets address the performance issue first. I have found that changing the scale from 1:100 to a larger scale can help in speed. One thing to keep in mind is what will your final presentation scale be. If you are going to be presenting at 1:500 I would make that my layer scale for all layers.
I don't know what interval you are using for the contours but you may want to change the detail here as well. For your work flow I generally work in top/plan and only switch to 3D to see what impacts my changes have on the model. If your shape shown above is a building I would sue the massing model and turn on the use as site modifier when setting this up. Hope this helps.
  • Love 1
thank you so much for the reply. it took me this long because I had to stop working for awhile but now im back with more queries as I have to finish school deadlines 😞
