Not sure if I've inadvertently changed a setting somewhere or if this is something that has appeared in 2018 SP5.1.
If I use the pointer tool to grab the handle at one end of a line, then when I move that end I expect to be able to snap to 90/45/30 degree angles by holding down the shift key.
However when I do this now, holding down the shift key will only let me move the end along a line that's a continuation of the existing line.
Attached screen recording shows me firstly drawing a line: when drawing the line, the angle snap works as expected. Secondly I try to reshape the line by moving one end of it. Without the shift key pressed, I can move it anywhere. With the shift key pressed, I can only move it along a continuation of the existing line.
line-weight
2 answers to this question
