Vortex box
Palle
Hi all,
I'm trying to generate an object to be produced IRL, inspired by the object in the reference image. But I want only a specified number of steps of framed boxes, until the inner box, which is a solid, as seen in the other image. I want to be able to tweak the parameters, so I can find the right scaling factor and rotation.
The parameters I want to control are:
> Dimensions of biggest box
> Total number of box repetitions.
> End angle of the solid (smallest) box
> The initial size of the profile for the frame boxes (which is also scaled down for each box in the ref image - but could be a fixed value in stead)
So far, I've built a script that makes solid cubes, scales and rotates them.
Two questions:
> I need a way to generate the frame boxes in stead of solid cubes. So I can actually see the framed boxes with the chosen profile size. This is my biggest struggle..
> And for versatility, a better way to generate the list of scaling values for the boxes. As is, I have to populate the list myself.
Any suggestions for other ways to better build a script like this is great.  Appreciate any help..!
Palle
Marionette Kais object.vwx
10 hours ago, Palle said:
Hi all,
Two questions:
Palle
Cool!
When you input something else then 9 into 'Number of Boxes', then it goes wrong. The squares are out of line and there are still 9. There are 9 outputs of the ordered list when you input 3 into Number of Boxes.
Maybe there is a solution without the ordered list with the [mul list] node (basic math), [Repeat], and [Sequence]?
34 minutes ago, STERNontwerp said:
There's a Mirror node in 'Operations'
But only for 2D objects, right? So, mirror all paths before extrusion?
And yes, I know the problem - and that's what I also want to solve. The ordered-list-node I use for generating the list of sizes does not relate to the input for number of boxes, so right now after changing the input, I would have to also make new nodes and connecting to make the sequence. Repeat and sequence. Will try that..
@Stephan Moenninghoff Thanks for the  code. However, I am looking for an expression that gives me size increments that are NOT constant. The have to gradually become less and less, never reaching zero. Therefore, I apply the scaling factor to each step.
The question is really, how do I express that in Marionette?
INPUTS:
- Start value
- Number of steps
- Scaling factor (i.e. 92% of previous list item)
OUTPUT:
Decreasing or increasing list of values
  • 3 weeks later...
Got back to the task - after some weeks away from it..
It's easy to input a list into rectangle/extrude nodes to give different sizes of closed boxes, but with my frame box (made inside the wrapper with solid boolean) is there a way to scale CSG solids - or - is there a way to input the different sizes in to this wrapper node
marionette Kais object 4.vwx
Edited by Palle
solved it
  • 2 weeks later...
Hi @Palle-
It looks like you have an integer node attached to the "vRot" input of the rectangle nodes in one of your wrappers. This input requires a vector - that is what the "v" means. It looks like all of the Int nodes you are using have a value of 0 so you are not looking to rotate any of the rectangles. If you simply remove these Int nodes and leave those rectangle inputs open the script will work how you want.
I noticed that your rectangle nodes are named and when I remove the Int node then those names appear on the outside of the wrapper. To keep this from happening, you can attach a 2D Vector node with the values of 1 for X and 0 for Y to the vRot inputs of the rectangles. Those are the default values for no rotation.
