NicoleD
Unable to Save Palette Positions
I have always had issues with my basic and tool sets palettes going back to default positions. Every time I open up VW, it goes to default and I have to drag them to my desired positions. About every week or so I save palette positions just to see if it works, but it never does. This happens regardless of being on a single or double monitor setup. Pictures attached are before and after I drag the tool sets. How can I get this to work properly?before.thumb.png.54ced66e75432cdbae83ef20e9b61207.pngafter.thumb.png.ea4b281dd68941315fa82c9b72ff4b5f.png
Share this post
Link to post
6 answers to this question
Do you by any chance use a 4k monitor? I've tried two different setups at 4k and neither of them works. The program window itself works fine, but palettes jump unpredictably at restart, and are not visible in the 2nd, 2k monitor. Or they disappear on the 2nd monitor after a while and cannot be found unless one unplugs the second display.
Share this post
Link to post
Just thought this might be a moment to note an irritating bug I have noticed regarding Palette position saving _ this related mainly to two monitor set up I work with .
Also related directly to position saving and Palette snapping ., which at least in my experience,  do not working use together ,
For a long period of time I dealt with the palettes on dual monitor set-up being thrown randomly onto one (main application) screen following VW reboot .... demanding the re-positionng of palettes on every application restart ,
VSS support here in UK could provide no obvious solution so I continued with this ..... until ......
I discovered this would only occurr with any palettes docked to each other ! Separate palettes would retain 2nd monitor location _ any palettes - tools / Object info/ navigation  etc docked to one and other would be forced to application (main) monitor on VW reboot .
I can deal with this quite easily but it does sort of make the whole palette docking feature a void in my case .....
VW 2018 & 19 Architect / Macpro / 2 X 27 " Apple displays ( one of which is Thunderbolt) .
Share this post
Link to post
Hi @NicoleD,
I used to have the same problem, and I found that somehow my User Folder directory was messed up. What I did to fix it was:
- Press Windows key + R, and type "regedit" in the dialog and hit OK.
- Once the "Registry Editor" window opens, go to this directory: Computer\HKEY_CURRENT_USER\Software\Nemetschek\Vectorworks 23\General
- On the right side of the window, make sure that you have your User Folder directory be something like this: C:\Users\YOUR_USERNAME\AppData\Roaming\Nemetschek\Vectorworks\2018\
- Restart VW and try to save the palette positions again.
I hope it helps!
Share this post
Link to post
I took a look, and everything is as it should be - thanks for the tip! Unfortunately it didn't do anything for my basic/tool sets & attributes palette. I'm thinking that maybe this might be fixed by going to 2019?
Share this post
Link to post
I'm sorry it doesn't work for you.
Yes it should. I've been saving the palette positions in VW2019 without any problems.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
