DBLD Posted June 20, 2018 Share Posted June 20, 2018 Hello I am having some issues with the fixture library. I am trying to use a rig of GLP GT-1's in Vectorworks and Vision, there are two issues here. The first issue is the GT-1 does not appear in the fixture library but it is in the GLP package found in the Service Select download section of the website. If I download this package and copy it to the Objects - Ent Lighting Instruments folder replacing the original GLP.vwx file the GT-1 does not appear in the library. If I open the GLP.vwx file I downloaded it contains the GT-1. Why is the fixture in the file but does not appear if I copy the file to the Objects - Ent Lighting Instruments folder? A workaround to this is to open the GLP.vwx file alongside the document I am working on, go to Resources and import the fixture from the GLP.vwx file into my document. This imports the fixture to the document I am working on but it is missing a fixture mode to use in Vision. Can anyone help with either of these issues? Cheers, Dan Quote Link to comment
markdd Posted June 20, 2018 Share Posted June 20, 2018 (edited) I have that symbol in my Service Select Library available from the resource browser. Are you sure you have the service select button selected on your resource browser? Also do you have Cloud services files enabled in preferences? Hope that helps? Edited June 20, 2018 by markdd Quote Link to comment
DBLD Posted June 20, 2018 Author Share Posted June 20, 2018 Hi Mark Thank you for your tips. Unfortunately both those things are enabled. Strangely my list of Service Select fixtures is a lot shorter than yours.. And this is the list of GLP fixtures I have which is in the Vectorworks Library as opposed to the Service Select Library. Cheers, Dan Quote Link to comment
markdd Posted June 20, 2018 Share Posted June 20, 2018 mmmm. Which country are you in? Maybe there is a different contract for different countries? Quote Link to comment
DBLD Posted June 20, 2018 Author Share Posted June 20, 2018 (edited) Ah yes, perhaps you are correct. I am in Australia. Can anyone from Vectorworks confirm that might be the case? Edited June 20, 2018 by DBLD Quote Link to comment
markdd Posted June 20, 2018 Share Posted June 20, 2018 (edited) I know the Architecture package is a little different in Australia. I would go and "question thoroughly" your local tech support! Edited June 20, 2018 by markdd Quote Link to comment
