  • 5
fabrica
Custom Cabinet Tool
The option to change the side width of the cabinets from the default 20mm would be very useful !
1 answer to this question
It generally would be very kind to be able edit ALL default values.
Like putting Config Files as Text or XML in the User Folder,
Overwrite by Workgroup Folder if existing,
Use System Folder if elsewhere broken,
Include a Custom Column to overwrite when needed while be able to still see the defaults.
When upgrading to a new VW Version, migrating what was before but adding new variables
not available before - and adding now incompatible values and new entries in an installation log.
For all defaults like VW default Classes generated for PIOs (like glazing-clear Class)
or imperial dimensions in PIO values (Glass Pane in Window about 0,003 mm)
and such things.
