Good morning,
Ran into quite an annoying bug this morning when trying to assemble a curved curtain wall.
Process -
first i created a curved polyline to be the shape of my wall
then used the tool distribute along path in order for me to segment my wall into workable corners
afterwards i followed the contours of the intersections between my lines and curved profile.
After assembly the wall, I noticed I cannot modify all the walls height at the same, and more importantly, when i reselect the walls - i cannot edit them anymore, as if a glitch happened.
I'm uploading a file for your review. Let me know if you can recreate the bug.
Note - you have to do it from scratch. If i close the file and reopen it, it doesn't reproduce the error anymore. I've reproduced this already on two machines.
Note 2 - If you try to modify the walls - it will show that it is a wall, but as if its stuck on a command. If you press ctrl-5, it resets the tool. very strange.
Note 3 - even after the quick fix, i notice the problem translates to other tools. In my opinion this could be a memory leak.
This bug is w/ Vectorworks 2018 SP 2. I haven't tried with others.
Sincerely,
Sam
Wall Glitch.vwx
Edited by Samuel Derenboim
1 answer to this question
I've just tested this in Vectorworks 2018 SP3 and none of the above issues occurred.
