halfcoupler Posted November 13, 2017 Share Posted November 13, 2017 Hi @ all, is there a way to print page count on reports sheets ? is there a way to have page headers / footers or at least have the report header/ footer repeated on each page ? Anyone who ever made handwritten notices on reports and afterwards let all papers of different reports fall on the floor may feel my pain.... Quote Link to comment
Pat Stanford Posted November 13, 2017 Share Posted November 13, 2017 Title blocks changed substantially in VW2018. Are you really on 2016 as your signature says? The proper response will depend on the version you are running. Quote Link to comment
halfcoupler Posted November 13, 2017 Author Share Posted November 13, 2017 Hi Pat, uups, sorry, diddn't update my old signature. I'm on VW 2018 ... I think title blocks are used for sheet layers only, not for reports ? Quote Link to comment
Pat Stanford Posted November 14, 2017 Share Posted November 14, 2017 To many people using to many different names for things. You said Report, I thought drawing set, you meant multi-page worksheet. (I think) I don't know of a way to format a worksheet so it shows page numbers directly. You could put it on the drawing and then create viewports of what should be on each page and then number them manually. Or you could print to PDF and use a PDF tool that can add page numbers. And you should enter an enhancement request if this is something you would like to see. Sorry to not be of more help. Quote Link to comment
halfcoupler Posted November 14, 2017 Author Share Posted November 14, 2017 Hi Pat, thanks much for your help, and don't feel stressed ... All I wanted to know if I had overseen some feature or workaround for the pagenumbers. So now it's clear: It's not possible without external software. Quote Link to comment
