Rolle Posted October 15, 2017 Share Posted October 15, 2017 In 2018 when coying and paste my objects disappear. By copying again and paste they appear. Anyone? Also: By marking an object and doubleclick rotate and rotate say 90° the object makes the same....disappear. There remains a "ghost", an orange line when you pass it with the cursor and its possible to copy, delete it and paste it again. Then it appears. Work on mac Sierra 10.12.6 Rolle Quote Link to comment
0 Art V Posted October 15, 2017 Share Posted October 15, 2017 What display setting are you using (Tools>Options>VW preferences and then display tab , navigations graphics item)? If it is set to best performance you may want trying to set it to good performance and compatibility as it sounds like a graphics display update issue. Quote Link to comment
0 Rolle Posted October 24, 2017 Author Share Posted October 24, 2017 Thanks but its down to Good Performance already! Quote Link to comment
0 Rolle Posted October 24, 2017 Author Share Posted October 24, 2017 The issue stays! Today I had to do like this. Every object I turned for ex. 90 degree the original object stayed and a ghost appeared that I had to copy, take away and paste in place. The original object still stayed. A little annoying I might say. Takes time! R Quote Link to comment
0 Art V Posted October 24, 2017 Share Posted October 24, 2017 It still does seem to be a display refresh issue. What are your hardware specs? Processor, graphics card, ram on machine and ram on graphics card etc. It could be they might not meet the minimum requirements for VW2018, though if you had no problems with VW2017 then VW2018 should work ok. Otherwise it is probably an issue for tech support to solve if the hardware is ok. Quote Link to comment
Rolle
Also:
Then it appears.
Rolle
4 answers to this question
