Sign in to follow this
Rolle
Pasted objects disappear
In 2018 when coying and paste my objects disappear.
By copying again and paste they appear. Anyone?
Also:
By marking an object and doubleclick rotate and rotate say 90° the object makes the same....disappear.
There remains a "ghost", an orange line when you pass it with the cursor and its possible to copy, delete it and paste it again.
Then it appears.
Work on mac Sierra 10.12.6
Rolle
Share this post
Link to post
4 answers to this question
What display setting are you using (Tools>Options>VW preferences and then display tab , navigations graphics item)?
If it is set to best performance you may want trying to set it to good performance and compatibility as it sounds like a graphics display update issue.
Share this post
Link to post
The issue stays! Today I had to do like this. Every object I turned for ex. 90 degree the original object stayed and a ghost appeared that I had to copy, take away and paste in place. The original object still stayed. A little annoying I might say. Takes time!
Share this post
Link to post
It still does seem to be a display refresh issue. What are your hardware specs? Processor, graphics card, ram on machine and ram on graphics card etc. It could be they might not meet the minimum requirements for VW2018, though if you had no problems with VW2017 then VW2018 should work ok.
Otherwise it is probably an issue for tech support to solve if the hardware is ok.
Share this post
Link to post
