  • 2
wprescott
Attaching objects to truss
I am having an issue getting things like Speaker Arrays, or projectors/Screens to attach to truss to be included in the weight calculations
ANyone have a solution?
4 answers to this question
I know probably silly question, but did you turn your truss into a hang position?  they should connect after it is converted.
so when you use the truss insertion tool i don't believe you have to. attaching lighting is fine its other things like speakers and screens.
but to answer your actual question, yes i have tried that but these things still dont attach properly to the truss.
ALSO, when i want to do arrays off a single point and there is no truss required, how do you get that to attach to each other. i have tried converting the arrays to truss but still no luck
the only work around i have found is to not include these items in the calculations and then inserting a load point on the truss where my speakers, screens, projectors, etc. are
I have done this and drawn things on a hanging position and they don't auto-attach.  I have to right click and manually attach everything other than lights.  (most of the time,  some times lights too)
I have the same issue.  2018 SP1.
