Developer Wiki and Function Reference Links Read more... ×
willofmaine
Nodes Excluded when Network Wrapped
When you wrap the script the 2 rotation nodes are left behind but in fact if you change the rotation parameter in the OIP it works normally. Now once the script is wrapped, if you delete the nodes it still works. Willofmaine have invented the ghost nodes!
In my case (French version) that’s what I get. What about you with your version?
To answer your question yes when moving the 2 nodes it wraps ok
 moving only the top one no changes
moving the bottom one wraps ok
Share this post
Link to post
Moving the excluded nodes in the original file only resolved the issue two times, out of about six attempts.  So, I completely replace those two nodes, and gave them one-word names (file attached).  This time moving the nodes only worked once out of about six attempts...
03-Nodes_Excluded_when_Wrapped-01.vwx
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
