rickpett Posted June 26, 2017 Share Posted June 26, 2017 imported vw2013 to vw2017 and lighting devices are greyed out. why is this? classes and layers are "on" Quote Link to comment
Andy Broomell Posted June 26, 2017 Share Posted June 26, 2017 Hmmm... Are Classes set to "Show/Snap/Modify" others? And Layers? Are you in Top/Plan? Quote Link to comment
rickpett Posted June 26, 2017 Author Share Posted June 26, 2017 Yes I am in top/plan. Classes are always in "Show/Snap/Modify" mode. Putting Layers in "Show/Snap/Modify" has no effect, plus LIGHTING was the active layer anyway. I've worked for years in "Show/Snap" for layers. Quote Link to comment
markdd Posted June 27, 2017 Share Posted June 27, 2017 (edited) There is some new functionality in later version of Spotlight which means there is now a Spotlight Preferences Dialogue. You can find this under the edit tab ( I think, I'm away from the computer at the moment) Here you can adjust some class related parameters which may be causing unexpected results. (Just a thought) Also, try editing one of the instrument symbols. That might make a difference? Edited June 27, 2017 by markdd Quote Link to comment
rickpett Posted June 27, 2017 Author Share Posted June 27, 2017 Weird but what I did was select all Moving lights, then, in attributes hit "make all attributes by class" Then repeated for lights and static accessories. Lighting positions all looked fine. Live and learn I guess. Quote Link to comment
