Greg Mix
2017 Renderworks not working and no textures loading
2017 Renderworks is not working and textures are not loading.  All objects with texture come up grey only.  Sometimes it will start working but then go out again.  Can see Open GL and Hidden Line, but any rendering beyond that and the object go invisible.  Holding cursor over things will highlight objects, but you have to go back to GL to see them again.  GL Options shows "Use Textures greyed out.  "I'm operating in Windows 7.  So far tech support has been unable to figure it out.
Any suggestions?
3 answers to this question
One thing to try is to downgrade the Navigation Graphics setting
 Vectorworks Prefs>Display Tab>Navigation Graphics: Highest level is Best Performance, so change away from that. I think vwx defaults to highest, as if everyone has the best, most current, most awesome CPU and GPU. Lowest level is Best Compatibility.
Hope this solves it!
-B
HI Greg,
Also experiencing the same problems. No textures appear. I only get white/grey objects. All textures appear in the resource browser but I can not open them, edited them, or do anything. I attempted to make new textures... however the dialogue box doesn't even open.
2017 / Windows 10
Did you ever find a fix?
@nknapke11 - Is Renderworks installed with your vwx installation? It might require a separate installation step.  Also try a lower Navigation Graphics choice - see above-  just to see if that has any effect.
-B
