nknapke11
    7
Everything posted by nknapke11
  1. Hi Andy! This worked! Thank you so much. Just like you said. Edit the texture in the resource manger and everything is work! Again thanks so much for your time.
  2. Hello! I"m trying to render some realistic lighting with several Plant inserted Via. the "Plant Tool". However it seems that plants inserted via the plant tool do not behave like Image Props.. When I try to render out any lighting, the plants go to "Full Brightness". (See attached image) I have attempted to make my own image prop.. and I turn off reflectivity.. and that seems to work... However, I spent quite some time inserting all of my plants, so the idea of doing all the work again with costume image props is not ideal. Any ideas? I'm really in a pickle.
  3. HI Greg, Also experiencing the same problems. No textures appear. I only get white/grey objects. All textures appear in the resource browser but I can not open them, edited them, or do anything. I attempted to make new textures... however the dialogue box doesn't even open. 2017 / Windows 10 Did you ever find a fix?
  4. Hi Rob, Awesome! Thanks for much for investigating this. I am able to use the SixPar with the Clamp and everything is good to go! Very very much appreciated. -Nathan
  5. Hi Rob! I'm trying to mount them from a vertical position. So I want the yoke of the fixture to be parallel to the "Floor".. So I clicked "3D Orientation" / rotate = 90 degrees... And that where I'm having the problems. See attached picture and .vmx. SixPar_Test.vwx
  6. Hi Rob! Thanks for the super quick response. I'm looking for the SixPar 300.. I attempted to using all of the sixpar models.. and they all "Flew Apart". I'm running 2017. Maybe I'm doing something wrong? Your time and efforts are greatly appreciated. -Nathan
  7. Hi Guys! I'm also having problems with the Elation SixPar "Flying apart" when 3D rotated... I went to Elation's website.. Attempted to open their 2016 vector works symbol, and I see nothing. Vector works opens but its a blank file. I might be doing something wrong..Could anyone help me out? Thanks!
