holbylarsen Posted May 16, 2017 Share Posted May 16, 2017 Hi I am looking at rigging projectors facing down, projecting on the floor. The video screen tool does not rotate 3D, so how can I achieve this? Thankful for advice Quote Link to comment
bcd Posted May 16, 2017 Share Posted May 16, 2017 Set Screen Tilt to 90º and Projector Tilt to -90º Quote Link to comment
holbylarsen Posted May 16, 2017 Author Share Posted May 16, 2017 (edited) Hi Thank you, that got me started. I am trying to make a projector with a .5 throw ratio and 16:10 that points straight down from a height of 3200 mm. The projector should be aligned to the bottom of the image. The projection surface is not below the projector though. And if i try to shift it I get warnings about parameters being beyond limits. Edited May 16, 2017 by holbylarsen Quote Link to comment
Kevin McAllister Posted May 16, 2017 Share Posted May 16, 2017 I'm not sure what you're trying to achieve is possible with the Video Screen tool. You're going to have to fake it in some way. One possible approach would be to put the projector on its own layer and set it up as needed assuming the "floor" is a vertical wall. Then create a design layer viewport of the projector layer and rotate it as needed within your 3d model. Kevin Projector Example.vwx Quote Link to comment
holbylarsen Posted May 16, 2017 Author Share Posted May 16, 2017 Thanks Kevin Maybe in future versions there will be an option like in the truss tool. For now I ended up building it from scratch with manual calculations. Quote Link to comment
