sbarrett 232 Posted March 1, 2017 Is there a way to insert an object into an existing symbol? I can't find any relevant calls in the "Object-Symbols" section of the developer page. Any help would be greatly appreciated. Thanks, Sarah Quote Share this post Link to post
Pat Stanford 1,626 Posted March 1, 2017 Get handles to the object you want to make part of the symbol and to the Symbol Definition. Then use Boolean:=SetParent(ObjHand, ContainerHand); (Sorry for the Vectorscript version. I am not up to speed enough to do Python of the top of my head.) 2 Quote Share this post Link to post
sbarrett 232 Posted March 1, 2017 Thanks Pat! That is exactly what I needed! Quote Share this post Link to post
AlanW 547 Posted March 1, 2017 Pat I just watch in awe at your knowledge of vectorscripting and your so willingness to respond all the time. thanks 1 Quote Share this post Link to post
DomC 320 Posted March 1, 2017 Always a relevation, an input from the master :-)) Me rookie scripter got so many inputs from Pat and other adepts, thanks at this at this point. Quote Share this post Link to post
Miguel Barrera 18 Posted March 4, 2017 You could also use the following command to copy an object into a container object: CreateDuplicateObject( objectToDuplicate :; containerHandle :) : ; Parameters objectToDuplicate HANDLE The object to be duplicated containerHandle HANDLE The container to the newly duplicated object Duplicates the specified object and inserts the new object into the container. If container is nil, the new object will be inserted in the active container. I use this to copy objects in a symbol into a pio where I can change the look of the objects without changing the symbol definition. Quote Share this post Link to post
