Flavio
Creating animation duration settings inactive
Hi,
While creating a short animation I have bumbed into a problem with the settings of the duration of my video.
If I use the mode "Orbit point" the software will let me edit the duration of the animation but if I switch to "move along path" it won't.
I have to say that  I have previously managed to extend the animation to up to 20 seconds in a previous test, but suddenly with my following tests something changed and now I am stuck with only 5 seconds animations.
Anyone having the same issue out there?
Thanks
1 answer to this question
Hi Flavio
I have just started looking into animation myself so found your answer.  When you edit the animation a time scale bar is visible.  When you drag your views in this a curve sort of connects them.  In the top right there is a triangle pointing backwards, double click on this and you can change the movie duration.
Best
Paul
