How to see studs in wall
jgmrussell
2 answers to this question
Hi rDesign,
Thanks for the heads up. I did manage to use the roof framing section but I'm having trouble with the wall framer. I'm attaching 2 things that might help with answer. One is the wall is angled down to zero on one side so the top plate is not straight and/or level, is this a problem? I'm unchecking all the layers that I don't want framed, just keeping the loft layer. When I do select loft only, I get the other message, see attachment. I'm doing something wrong, just can't figure it out.
Thanks again,
John
