jmartinarch Posted November 11, 2016 Share Posted November 11, 2016 Why won't TAP fill the text? I managed to get it to work once but cannot replicate. What is the secret? Quote Link to comment
Marionette Maven Marissa Farrell Posted November 11, 2016 Marionette Maven Share Posted November 11, 2016 Do you have the "Text Type As" field set to surface? (although in Top/Plan you still likely won't see a difference) Quote Link to comment
Marionette Maven Marissa Farrell Posted November 11, 2016 Marionette Maven Share Posted November 11, 2016 Update: I actually did get it to work in Top/Plan just using curves, so that may not be it. Quote Link to comment
AlanW Posted November 11, 2016 Share Posted November 11, 2016 (edited) Hi Use Text type as 'Curves"??? this works. See attached Fill Text.vwx Edited November 11, 2016 by Alan Woodwell Quote Link to comment
jmartinarch Posted November 11, 2016 Author Share Posted November 11, 2016 It is more than just "curves" option. I think it has more to do with class settings, fill options etc. As I had used "curves" before. Thanks all for good suggestions. Quote Link to comment
AlanW Posted November 11, 2016 Share Posted November 11, 2016 If you don't have the class set to use at creation and solid (pick a colour) it will not fill. Quote Link to comment
