decayny96 Posted September 30, 2016 Share Posted September 30, 2016 When I generate a Door Schedule in VW2014 using the Door ID record and I summarize quantities of doors it also summarizes the dimensions - i.e., 10 3'-0" doors show up as 30'-0". I don't want that - I want it to show the size [height, width and thickness] for ONE door of that type. How do I achieve this? Quote Link to comment
Pat Stanford Posted September 30, 2016 Share Posted September 30, 2016 Drag a second SUM tile (icon) to the columns that you don't want summed. That will then give you the average for those rows. It is up to you to make sure you are only summarizing doors with the same dimensions. 2 Quote Link to comment
decayny96 Posted September 30, 2016 Author Share Posted September 30, 2016 Oh, that was quite easy. Thanks. The other question I had was, when I use the pre-formatted VA Door Schedule in the Tool menu, I am not given the option to include symbols and PIO's. I only have that option when I create my own new schedule in "Create Report..." Is there an easy way to edit the VA Door Schedule to do this. Quote Link to comment
Tom Klaber Posted September 30, 2016 Share Posted September 30, 2016 Easy is relative, but you are able to add columns and call whatever data you want. Just go to the Database header on the new column and call the data using the =('Door'.'xxx') - Replace the xxx with the data field you are trying to call. Quote Link to comment
Pat Stanford Posted September 30, 2016 Share Posted September 30, 2016 To edit the default schedule you need to do a couple of steps. 1. Open the worksheet for editing. 2. Select a line in the database section of the worksheet (say 4.1) 3. Choose Database Headers from the Worksheet View Menu 4. Select the Schedule header row (e.g. 4, not 4.1, 4.2, etc.) 5. Right click in the row header 6. Choose Edit Criteria 7. Click the PIO and Symbol check boxes. 8. Click OK. 9. Unselect Database Headers from the worksheet View menu. 1 Quote Link to comment
