johan23 Posted September 26, 2016 Share Posted September 26, 2016 Can I use (or is there some way to use) a vectorworks 13 windows file in vectorworks 12.5 windows? Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted September 26, 2016 Vectorworks, Inc Employee Share Posted September 26, 2016 Do you mean Vectorworks 2013? You would have to open the file in Vectorworks 2013 and then use File > Export > Export to Vectorworks 12 format. Modern versions of Vectorworks are not capable of exporting that many versions back. Quote Link to comment
0 Art V Posted September 26, 2016 Share Posted September 26, 2016 Also, if you intend to upgrade to a newer VW version (e.g. 2017) make sure you keep your older VW versions install files as well if you ever need to export to an older format no longer supported by the latest VW version. It is one reason why I still keep VW2015 installed, so that I can convert to VW2015 and then to a version older than VW2017 can export to. Quote Link to comment
johan23
2 answers to this question
