Andrew Mac Posted August 14, 2016 Share Posted August 14, 2016 I was wondering if there is a easy way to join wall that have a straight runs that are different thicknesses. Basically to show the wall is furred out Quote Link to comment
zoomer Posted August 14, 2016 Share Posted August 14, 2016 A new Wall Style for each step ? (If I got that "furred out" right ) Quote Link to comment
rDesign Posted August 14, 2016 Share Posted August 14, 2016 Zoomer's suggestion would work, or you could use a Wall Projection. 1. Create the Wall (with components); 2. Create a 2d object the size of what you want to be furred out; 3. Select both the wall and the 2d object and select AEC > Create Wall Projection... 4. Set the component wrapping options accordingly. Quote Link to comment
