Josh NZ Posted August 12, 2016 Share Posted August 12, 2016 (edited) I'm experiencing a strange problem in a set of files. If I draw a 2D object and set the fill to white the white does't show. In the attached image I have turned my background to grey to easily show whats happening. The box on the right and the text have a white background but appear transparent. If I drag a copy to the left and change fill to say blue then it shows fine. Objects plane is set to screen, objects are classed none, objects use white fill or class fill as white and still doesn't show. view is set to top/plan. Have tried on three computers and all experience the same, have attached example file. I'm guessing there some setting I have accidentally changed but can't think what that might be. Any ideas? Edited August 12, 2016 by Josh NZ Quote Link to comment
Josh NZ Posted August 12, 2016 Author Share Posted August 12, 2016 I should add that the 2D objects still behave like they have a fill, as in if you click in the centre it still selects the rectangle. IF you have no fill it won't select. If I class the rectanlge and view in a sheet layer viewport it still appears transparent. Quote Link to comment
zoomer Posted August 12, 2016 Share Posted August 12, 2016 (edited) If you remove the 50% opacity from your Layer it will work. Not sure if you need that transparency for some reason and why it doesn't work with Layer transparency .... EDIT : Funny, it works with 50% Class transparency as expected Edited August 12, 2016 by zoomer Quote Link to comment
