lolo66 Posted July 27, 2016 Share Posted July 27, 2016 Hi there, I'm trying to edit my window to have a central sash of 250mm and panes of glass either side of 330mm each. When I edit the sash width, it edits all the sash panels- so the panels on either side of the glass, but I only want to edit the central sash as it's a lot wider than the others at 250mm. Is there a way to do this? From what I can see, I cant edit the glass panes, im guessing that they're measurement adjusts depending on the other values? Many thanks! Lois Quote Link to comment
AlanW Posted July 27, 2016 Share Posted July 27, 2016 Do you have the option to select colonial air prairie type, I think the prairie allow you to have wider in centre. HTH Quote Link to comment
lolo66 Posted July 29, 2016 Author Share Posted July 29, 2016 Hi Alan, Is that under the Jamb and Sash section? I can't find it. Thanks Quote Link to comment
