Josh NZ Posted July 11, 2016 Share Posted July 11, 2016 Hoping someone can assist. There is an item which I cannot remove from a worksheet (contents). The worksheet is simple enough, basically retrieves the info from a titleblock if a field in the record format is present. I have deleted all objects in the file, and also done a purge. The worksheet still shows a line. Have tried clicking "select item" and nothing is selected. Thanks in advance, file attached. Quote Link to comment
michaelk Posted July 11, 2016 Share Posted July 11, 2016 That line in the worksheet is actually returning the name of a sheet layer. If you delete the sheet layer, then the line will go away. hth mk Quote Link to comment
