halfcoupler Posted June 15, 2016 Share Posted June 15, 2016 How can I set the section Line Style generally by default to "Drawing No only" and "Text Both Ends" ? Do I have to set that in a template ?? Can't find it.... Thanks for Help :-) Quote Link to comment
mike m oz Posted June 16, 2016 Share Posted June 16, 2016 - Select the Section-Elevation Line tool on the Annotation tool palette. - Click on the Preferences button on the Tool Bar. - In the Object Properties dialog box that opens set the tool Preferences as you want them. - Click OK to exit and this will define the tool preferences for this document from now on. This method can be used to set the tool Preferences for most tools. The trick is to set them before you use the tool. Doing it to the object afterwards only affects that selected object. If you have particular preferences you want then take the time to do them in a Template File and then re-save the file as a Template File so it overwrites the original Template File. Quote Link to comment
Guest Wes Gardner Posted June 16, 2016 Share Posted June 16, 2016 ^ What he said...:-) Quote Link to comment
halfcoupler Posted June 17, 2016 Author Share Posted June 17, 2016 Thanks much, that was exactly what I was looking for... Quote Link to comment
