lolo66 Posted June 8, 2016 Share Posted June 8, 2016 Hi, Could anyone please tell me how I alter the window I'm trying to draw....It's a double opening window but one pane of glass is bigger then the other so the window is not symmetrical. I'm using the window tool under the tool sets. I've tried looking on the window settings and can't figure it out! Any help would be much appreciated! Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 8, 2016 Vectorworks, Inc Employee Share Posted June 8, 2016 Under the Jamb and Sash pane on the left of the Window settings dialog, uncheck: "Unequal Sash" Quote Link to comment
lolo66 Posted June 9, 2016 Author Share Posted June 9, 2016 (edited) Ah yes I've found it! Although it won't let me check it, it's greyed out. I'm fiddling with the settings to see how I can get the box to become black so I can check it (as I want the window panes to be unequal.) Not having much luck here. :crazy: Edited June 9, 2016 by lolo66 Quote Link to comment
bcd Posted June 9, 2016 Share Posted June 9, 2016 Try General>Sash>Custom>Custom Sash Options>Num. of Rows = 2 Define the left sash or use the >> button on the bottom left to select and define right sash. Quote Link to comment
lolo66 Posted June 9, 2016 Author Share Posted June 9, 2016 Ah yes, i've done it! Thank you! I need to show the windows as open, and when I do that, a red box in the bottom right hand corner of the screen says 'The selected object has no edit behaviour.' Could anyone shed some light on how to overcome this? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 9, 2016 Vectorworks, Inc Employee Share Posted June 9, 2016 With that window selected, does it say "Window" at the top of the Object Info Palette? Or do you have some other kind of object highlighted? Quote Link to comment
lolo66 Posted June 9, 2016 Author Share Posted June 9, 2016 It says 'Window in Wall.' Many thanks for your reply. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 9, 2016 Vectorworks, Inc Employee Share Posted June 9, 2016 Post a VWX file with that window and its associated wall please, I can take a look. Quote Link to comment
lolo66 Posted June 9, 2016 Author Share Posted June 9, 2016 Thank you! I have linked the file. Quote Link to comment
