bcd Posted May 27, 2016 Share Posted May 27, 2016 We need to be able to link to documents and use the PDF created by VW as a link-rich navigation sheet for a depositorary of documents (eg pdf's). From the help file this is currently not possible: "DesignSeries.pngExporting Hyperlinks to PDF Only hyperlinks that open a web page or navigate to a sheet layer are functional when exported to a PDF file." Quote Link to comment
0 Tom Klaber Posted May 31, 2016 Share Posted May 31, 2016 Have you tried the "Hyperlink" tool? I have not used it extensively, but it allows you to add a link that will go to a web page, saved view, document, or folder. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted May 31, 2016 Vectorworks, Inc Employee Share Posted May 31, 2016 That's what bcd means, basically enhance the hyperlink tool so that it can also open other PDFs from an exported PDF. Generally this is done (in software that supports linking other PDF documents) via relative file links, so for example any PDF in the same folder as the active PDF could be linked to. Quote Link to comment
0 bcd Posted May 31, 2016 Author Share Posted May 31, 2016 Thank you Jim. Exactly. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted May 31, 2016 Vectorworks, Inc Employee Share Posted May 31, 2016 Also: The request was submitted. Sorry, forgot to add that part earlier! Quote Link to comment
0 Tom Klaber Posted June 7, 2016 Share Posted June 7, 2016 Reference markers should have the ability to act as hyperlinks as well. This should be automatic if they are linked to a viewport. Quote Link to comment
bcd
5 answers to this question
