LarryO Posted March 16, 2016 Share Posted March 16, 2016 Which function permits the setting to be achieved? When using PrimaryUnits or Units the 'Rounding Style' will change to Fractional or Decimal. We want to be able to return it to 'Exact as Fractions / Non-Exact as Decimals'. My searching has yielded no results as usual. Arrgh Quote Link to comment
WhoCanDo Posted March 17, 2016 Share Posted March 17, 2016 One option I have used is to set the units as you want them in a blank sheet and then export the script and see what you get. I used Excel to compare two scripts by pasting each into columns A & B and then by using the code.. =IF(A2=B2,"",1) in column C (dragged down) Quote Link to comment
MullinRJ Posted March 17, 2016 Share Posted March 17, 2016 Hello LarryO, 175 is the preference number you need. However, to set Pref 175 to TRUE, Preference 168 must already be set to TRUE. So, try this two line script to return VW to the way you like: SetPref(168, True); { Rounding Style: Fractional } SetPref(175, True); { Exact as Fractions / Non-Exact as Decimals } Raymond Quote Link to comment
LarryO Posted April 12, 2016 Author Share Posted April 12, 2016 Thanks guys for the answers. I will now be able to update my tools so they leave the drawing file settings as found. Yeah Quote Link to comment
