Patrick Winkler
'Print'-Node / An easy way to debug Wrappers
This Node makes debugging more comfortable especially inside wrappers.
You can select weather if the incoming values will be printed into a text object right under the node or into the python console.
Time of the execution and type of the items can be printed optionally. I integradet the object type list from the appendix site to translate the type id into a string ( 5 = Polygon... ).
Tell me if you miss some feature.
ubbthreads.php?ubb=download&Number=14560&filename=Bildschirmfoto%202016-03-01%20um%2014.27.02.png
Edited by Patrick Winkler
Awesome, very, very helpful!!!
Edited by DomC
Patrick,
Sorry for the NOOB question but how do I get to the
"Select the console as print target"
Thanks
Hi
I added a function to move the print through the info palette of the Marionette object.
So I can have as many prints as I want and see all the "printed" values at once
Edited by mattao
thanks mattao,
I've merged your option into the actual version.
The position can be set in the OIP, if the option 'Autom. Position' is checked the TextObject will be put under the node.
The other new option is 'Autom. TextSize'.
This option sets the Textsize of the TextObject to the biggest Textsize of the Node.
