Blissab Posted May 24, 2015 Share Posted May 24, 2015 (edited) Hello Everyone, I'm working my way through a Vectorworks tutorial and as part of the 3D modeling section of the tutorial, I am modeling a plate bracket with some 1/2" diameter holes. Both the tutorial book and related video has directed me to access the View Bar and activate the Automatic Working Plane(when activated, the bracket model highlights blue when the cursor touches a surface), before modeling the holes. When I go to the Active Plane pull-down menu I only have "Layer Plane", "Screen Plane" and "Options" available and no "Automatic" working plane. When I toggle the Backslash key, I receive the message: "Automatic Working Plane mode is not available in current context". What does this mean? I don't believe that I have missed any steps in the process, so I am confused as to how to active the Automatic Working Plane. The tutorial has no indication as to how to make this activation, when the Automatic Working Plane is not available and the Vectorworks help section does not discuss how to activate this. Can anyone help. Thank you, AB Edited May 24, 2015 by Blissab Quote Link to comment
AlanW Posted May 24, 2015 Share Posted May 24, 2015 I have found that only when you activate certain commands the auto working plane command becomes active. Hopefully someone will provide a clear answer as to what category of commands activate this. Quote Link to comment
Blissab Posted May 24, 2015 Author Share Posted May 24, 2015 Thank Alan for your response. I am following along with a tutorial, which is placing holes (circles) in a steel plate. In the tutorial video of this process, the creator indicates the Automatic Working Plane within the Active Plane pull-down. In my process of placing holes (circles), Automatic Working Plane does not exist. I have been careful, to follow the process step by step. AB Quote Link to comment
Blissab Posted May 24, 2015 Author Share Posted May 24, 2015 Hello Alan, I just figured-out the Automatic Working Plane activation. You have to be within one of the basic tool commands to activate the Automatic Working Plane in the Active Plane pull-down. I was mistakenly trying to accomplish this prior to selecting one of the basic tool commands. Its a matter of sequence. Thank you, AB Quote Link to comment
barkest Posted May 25, 2015 Share Posted May 25, 2015 You have to have a drawing tool selected: rectangle, circle etc. Quote Link to comment
