JoeBayLD Posted December 2, 2014 Share Posted December 2, 2014 Any idea how to implement the vs.NotifyPullDownClicked command? I tried adding a definition: def vs.NotifyPullDownClicked(dialog, kLocationChooser): do something and it doesn't work. I need to know when the user selects a pulldown menu. Ideas? Quote Link to comment
JBenghiat Posted December 3, 2014 Share Posted December 3, 2014 Have you written the dialog handler yet? There is an example here: http://developer.vectorworks.net/index.php/VS:RunLayoutDialog You insert the NotifyPullDownClicked call in the setup portion of the handler (item==vs. SetupDialogC). Then, when item== kLocationChooser, you know the user has clicked the pulldown. -Josh Quote Link to comment
