J. Wallace Posted July 16, 2014 Share Posted July 16, 2014 (edited) This is a new and a bit of an odd one. I have a very small, simple model I'm placing a deck on, this is the waters edge not the side of a house. I need to place a small pad which went well, then I needed some grade limits. Every time I create one I get this...the grade limits instead of being dotted blue line weight they're filled and you don't seem to be able to change this regardless of class. For your info: When I create any site modifier I usually draw a polyline then create object from shape. You can see in the second image that the fill colour is also present in a 3d view. Edited July 16, 2014 by J. Wallace 1 Quote Link to comment
CipesDesign Posted July 17, 2014 Share Posted July 17, 2014 Hi JW, I would need to see the file to be sure, but this sort of thing smells like a class controlled attributes thing. Was the original object classed none, or some other class? Is the Site Modifier Class set to Use at Creation; and what is it set to? Beyond that, if all your Site Modifiers are in the Site Modifier Class (or some other discreet class or classes), you can make that/those class(es) invisible. The Site Model will still think they are there, but you won't see them or their attributes. Hope that helps! Quote Link to comment
Emma Karlsson Posted November 19, 2021 Share Posted November 19, 2021 We have the same problem. Did you manage to solve it? Quote Link to comment
