Phil hunt Posted May 6, 2014 Share Posted May 6, 2014 i have created my floor plan as a viewport, from my plan on my design and then created a section viewport from the plan on my design layer..... when i go into the viewport with the plan, the section viewport shows the notes elevation AA ok but it does not show up on the plan in the viewport, i just can't remember how to do this any help would be appreciated thanks Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 6, 2014 Vectorworks, Inc Employee Share Posted May 6, 2014 I believe you have to select the original section viewport, then in the Object Info palette, near the bottom, click "Section Line Instances" and specify the viewport you want it to be shown in. Quote Link to comment
Phil hunt Posted May 6, 2014 Author Share Posted May 6, 2014 Perfect thanks Jim Quote Link to comment
Phil hunt Posted May 7, 2014 Author Share Posted May 7, 2014 when i am making a section viewport to create an elevation, i click once at the start and finish of the section of wall i want to show but when it creates the viewport it shows the walls either side of the section viewport, do i then have to adjust the crop in the viewport to only show the section of the walls i want. thanks Quote Link to comment
michaelk Posted May 7, 2014 Share Posted May 7, 2014 In the section viewport's OIP: Advanced Properties > Extent Tab > set Length Range to Set by Section Line Length. hth mk Quote Link to comment
