Kevin McAllister Posted January 11, 2013 Share Posted January 11, 2013 I'm having trouble with objects holding their "By Class" opacity. The objects are JPG images. If I assign them to a class where all objects take on class attributes at creation and the opacity is set at 50% they initially take the setting. Then if I zoom in or out their opacity snaps back to 100% and they lose their "By Class" settings. If I manually set them to 50% instead of "By Class" they will hold their setting. Has anyone else had this issue? Kevin Quote Link to comment
CipesDesign Posted January 12, 2013 Share Posted January 12, 2013 Sounds a lot like a bug to me... If you can repeat the failure by known steps (and it sounds like you can) then I would submit it to BugSubmit. Quote Link to comment
jmoore Posted February 13, 2013 Share Posted February 13, 2013 Hi Kevin, Ya, we are seeing exactly the same issue...... If you figure it out other than a SP update from VW, please post back here. I'll do the same. Quote Link to comment
Kevin McAllister Posted February 14, 2013 Author Share Posted February 14, 2013 It was filed as a bug through my distributor, who was also able to duplicate the problem. KM Quote Link to comment
