Christian Fekete Posted November 20, 2012 Share Posted November 20, 2012 I usually use the plugin provided by VW but the profiles do not match the manufacturers details. I noticed that you can insert a symbol instead from inside the Object info panel. Do you insert a 3d symbol? Are these fixed or can you change the dimensions? I would like to be able to create proper elevation and wall sections.. Is there a section of the help that treats o the subject online? Thank you Quote Link to comment
Jonathan Pickup Posted November 21, 2012 Share Posted November 21, 2012 Do you insert a 3d symbol? if you want, you can use a hybrid symbol Are these fixed or can you change the dimensions? fixed Quote Link to comment
Jonathan Pickup Posted November 21, 2012 Share Posted November 21, 2012 Here is a movie that shows how to do this http://learn.archoncad.com/2012/11/9920/epodcast166-creating-a-demolished-window/ Quote Link to comment
Bob Holtzmann Posted November 21, 2012 Share Posted November 21, 2012 I'm getting into the habit of making plug-in doors and windows w/ the settings the way I want them, and then make symbols of them. The symbol can then later be edited, by just changing the plug-in settings. Quote Link to comment
VincentCuclair Posted November 21, 2012 Share Posted November 21, 2012 (edited) I'm getting into the habit of making plug-in doors and windows w/ the settings the way I want them, and then make symbols of them. The symbol can then later be edited, by just changing the plug-in settings. Don't you have problems with offsets in wall, corner windows etc. using this method? Edited November 21, 2012 by Vincent C Quote Link to comment
Christian Fekete Posted November 21, 2012 Author Share Posted November 21, 2012 Hi Jonathan; Just signed up to see your demo, great information. I look forward to viewing all the information. I have a quick question regarding windows and doors showing sills where there is none. I know, I found the answer before but I can't seem to get rid of the black line anymore. what is the trick? Thanks Quote Link to comment
Jonathan Pickup Posted November 21, 2012 Share Posted November 21, 2012 turn off the class, ceiling is it? Quote Link to comment
Christian Fekete Posted November 22, 2012 Author Share Posted November 22, 2012 Will try thank you Quote Link to comment
