digitalcarbon Posted October 23, 2012 Share Posted October 23, 2012 is there a way to do this? http://youtu.be/Q7XoGDvVVU0 Quote Link to comment
mike m oz Posted October 23, 2012 Share Posted October 23, 2012 (edited) When you delete a Line Type the lines revert to solid lines. If you want to change them to another Line Type use this method: - Import the Line Type you want so it becomes a resource in the active file. - Select the objects with the Line Type you want to change using either the Select Similar tool or Custom Select. - In the Resource Browser double click on the Line Type you want to replace the selected objects with. You can then delete the Line Type you don't want if you so wish. Edited October 23, 2012 by mike m oz Quote Link to comment
