change viewport update status?
michaelk
Is this a bad idea??
I'd like to be able to reset the "need to update" status on sheet layer viewports.
There are many times when I change the manufacturer's model number in a worksheet and a most of the SL viewports show the red barber pole lines. Or I change the graphic attributes of a section line and the section viewport (unnecessarily) shows that it needs to be updated.
Has anyone ever tried this?
Are there any problems to be aware of?
Is this the correct procedure: SetObjectVariableBoolean(SLViewportHandle,122,FALSE)
Thanks
MK
Another related question.
Below is a quote from the VS reference for SetObjectVariableBoolean
The description of the procedure has a handle argument, but the example doesn't.
It won't run without the handle argument, but it doesn't change the boolean variable with it.
Help
mk
VS:SetObjectVariableBoolean
Description
Sets the ON-OFF status of a VectorWorks object property.
For specific object selector index values, see the Appendix.
PROCEDURE SetObjectVariableBoolean(
h :HANDLE;
index :INTEGER;
status :BOOLEAN);
Parameters
h HANDLE Handle to object.
index INTEGER Object property index.
status BOOLEAN New status for property.
Example
SetObjectVariableBoolean(17,FALSE);
