Event Seating
bcd
  • 1 month later...
The event seating looks for other objects placed by the event planning commands to use as a look to point. If none of those objects exists it places the look to point close to the center of the seating layout.
From there you can grab the control point and move it to where you need it. The simplest option is to snap it to the midpoint of what you want to be the front of the seating area.
It's impossible for the command to determine where the front of the seating is without finding some other object.
If you want to place the look to point when you are creating the seating area use the create seating layout command.
