Nico_be Posted September 11, 2011 Share Posted September 11, 2011 Hallo, Here is un script found on another site. This script place all symbol include in the file, in all folders, on the drawing. Marvelous to create after that a tablelist and edit directly in the table. But the script crashes at the end of the process!! is somebody could take a look at it and see the error? Pleeaase ! :crazy: PROCEDURE ShowAllSymbols; {?1999 Graphsoft, Inc.} {The traverseSymbolList procedure was developed by Craig Hollinshead.} VAR numFolders, numNestedFolders, numSymbols : INTEGER; messageString : STRING; OK : BOOLEAN; NewPtSize : INTEGER; OldPtSize : INTEGER; SelectedObj : HANDLE; TheSymbolName : STRING; SymFolderName : STRING; TheSymDef : HANDLE; SymDef2 : HANDLE; ChangeAllLines : BOOLEAN; CurrLayer : HANDLE; X,Y : REAL; XSpacing, YSpacing : REAL; NumAcross : INTEGER; StartX,StartY : REAL; LayerNames : ARRAY[0..200] OF STRING; Index : INTEGER; {=============================================================================} PROCEDURE TraverseSymbol(theSym:Handle); VAR symObjClass : STRING; origLineWt : INTEGER; symName : STRING; symInstance : HANDLE; sX1,sX2,sY1,sY2 : REAL; BEGIN symName := GetSDName(theSym); symName := GetName(theSym); Symbol(symName,X,Y,0); symInstance := LNewObj; GetBBox(symInstance,sX1,sY1,sX2,sY2); TextFace([bold]); TextOrigin(sX1,sY2-1); BeginText; symName EndText; X := X + XSpacing; IF (X > (StartX + (NumAcross * XSpacing))) THEN BEGIN X := StartX; Y := StartY - YSpacing; END; Message(concat('The Sym#',Num2Str(0,numSymbols),' is - ',symName)); END; {PROCEDURE TraverseSymbol} {==============================================================} PROCEDURE traverseSymbolList (itemHdl:HANDLE); BEGIN WHILE (itemHdl <> NIL) DO BEGIN CASE GetType (itemHdl) OF 16:BEGIN TraverseSymbol(itemHdl); numSymbols := numSymbols + 1; END; 92:BEGIN SymFolderName := GetName(itemHdl); numFolders := numFolders + 1; numNestedFolders := numNestedFolders + 1; LayerNames[numFolders] := SymFolderName; Layer(SymFolderName); X := StartX; Y := StartY; TraverseSymbolList (FInFolder (itemHdl)); END; END; {CASE GetType (itemHdl)} itemHdl := NextObj (itemHdl); END; {WHILE (itemHdl <> NIL)} IF numNestedFolders > 0 THEN numNestedFolders := numNestedFolders - 1; END; {PROCEDURE traverseSymbolList} {==============================================================} BEGIN {*/// Main program ///*} XSpacing := DistDialog('Enter Horizontal Spacing Distance:',''); YSpacing := DistDialog('Enter Vertical Spacing Distance:',''); NumAcross := IntDialog('Enter the number of symbols per row',''); Message('Click on top left corner of the grid'); GetPt(StartX,StartY); CurrLayer := ActLayer; numFolders := 0; numNestedFolders := 0; numSymbols := 0; X := StartX; Y := StartY; LayerNames[0] := GetLName(ActLayer); IF FSymDef <> NIL THEN TraverseSymbolList (FSymDef); Index := 0; Layer(LayerNames[index]); WHILE (FInLayer(ActLayer) = NIL) DO BEGIN Index := Index + 1; Layer(LayerNames[index]); END; SetLayerOptions(1); Redraw; ClrMessage; END; {PROCEDURE ShowAllSymbols} RUN (ShowAllSymbols); Thanks!! jab Quote Link to comment
WhoCanDo Posted November 2, 2011 Share Posted November 2, 2011 I have VW 2010 SP4 Fundamentals and it works for me. Regards Quote Link to comment
