152 -
Everything posted by Nico_be
Providing existing and proposed site model elevations
Nico_be replied to Rebecca R's topic in Site Design
Hello, There is the "terrain section" command (I don't know its name in the US versions), it generates a profile with the existing and the proposed. A very basic command that it would be nice to update as already requested several times in the WishLists, but hey it's a base to work on. -
Graphic legend - version for non-data objects
Nico_be replied to Amanda McDermott's question in Wishlist - Feature and Content Requests
It doesn't seem to work with geometric patterns, but it does with hatches. And for plants, I can't see, it doesn't seem to work with parametric objects, it's an old plugin. -
Sorry, i'm still with VW203, can you export in this version? -
could you share here a test file? -
rectangles are filled e, depending on the class settings, which will be noted as the fill color and line. For symbols, you need to give the scale of each symbol so that it can be adjusted. If you get this message, the symbol is probably too large, Could you paste here a printscreen? -
Okay, for many years I've been using a plug-in. I think its author had made it freely available a long time ago. It does EXACTLY what a caption tool should do: you select the symbols and classes you want to caption and you can specify what you want in text. And set the number of columns, spacing etc. Because the new tool since VW2023 is not usable by me. There's no point in entering the class name as it is, I want to be able to enter the text I want. I still use this old plugin as long as it's compatible with new versions, it's much simpler. I'm attaching it here, and you need to put the files and folders in the "PLUGIN" directory and add it to the configuration. It had been developed in Belgium, I hope it will work for other versions, let me know. dieterdworks-vw-dlegend-1fb9b3fefaa7.zip -
Another solution is to create a simple worksheet, with the formula =IMAGE in the first column, which will display the symbol's image. The other columns can display other plant information. There are example tables already available in the library. I'm in French so I don't know the name of the command in other language versions.
Several database functions in one table cell
Nico_be replied to Nico_be's topic in General Discussion
Ok Pat, I'll have a look at graphical legend, it's probably a beter idea! Thanks. -
Yes, that's what I've done, I've recreated a new table, I'm getting something more interesting in the formatting of the data, but there's the problem of character limitation which doesn't display all the information in the field. I can't find any information about this anywhere. The new file is attached Test tableau Copie3.vwx -
there seems to be a bug with the tables, the formula works in one table of the file but not in the other. It doesn't make searching any easier 🙂 But there's still the problem of character limitation. second file attached. Test tableau Copie2.vwx -
Thanks for your help already! 🙂 To sum up, here's the objective: To have several fields in a single table cell, in an attempt to create a more interesting layout than a simple table. The test file is appended. in the meantime I had found the CHAR(10) trick: https://developer.vectorworks.net/index.php/VS:Chr What almost works: The CONCAT formula refers to cells in the same table. =CONCAT(D3; (CHAR(13)); 'Flowering: '; E3; (CHAR(13)); (CHAR(13)); 'In a few words: '; F3) But it seems that the number of characters is limited, as the end of the text in F3 is missing. I couldn't find any information on character limitation in the reference manual. Another problem is that I have to refer to columns in the same table, which is inconvenient for printing. I've tried referencing the data in the other table but as it's a dynamic list this doesn't work as it returns the value of the leading row only, not the list. I've tried @Pat Stanford's formula, but it doesn't work (I'm running Windows 10, so I've replaced the commas (,) with semicolons (;) ). Any idea? Test tableau Copie.vwx -
And yes, it works! By making a small file to send here, I redid the test and it works perfectly. I probably made a syntax error on my first try. Thanks a lot! While I'm at it: can I insert a "line feed" in a formula? I'm trying to create a more interesting layout than simple lines... -
nothing appears in the list of objects concerned by the criteria: the cells are empty. -
unfortunately it doesn't work, I tried. -
Hello, Is it possible to place a formula with several database functions in a single cell? And even add a fixed text? For example, for plants, can we group these two cells into one? Instead of having : A1 : =('Plant Record'.'Botanical name') A2: ='Plant Record'.'Remark 1'. Have something like this : A3: ==('Plant Record'.'Botanical name') ???? ('Plant Record'.'Remark 1') Thanks a lot!
Yes, you need to edit the plant style and change the label parameters from "by style" to "by object".
- 1 reply
- 1
Landmark - Plant Schedule displaying image of plant
Nico_be replied to J.Aspect's topic in Marionette
I have already tried to modify the PlantRecord fields but without success. I have the impression that it works, but in reality the fields are not modified. I'm interested in this subject. -
Script to change the parameters of a plant from "by style" to "by object"
Nico_be replied to Nico_be's topic in Site Design
Hello @Katarina Ollikainen Would it be possible to insert this script into a more complex script that would allow multiple parameters to be changed at once, instead of rerunning it for each parameter? Or turn it into a marionette node? -
This is exactly the script I was hoping for! Great, thanks @Katarina Ollikainen ! -
Hello, I'm looking for a way to change the parameters of a plant style automatically on dozens of plants at a time, via a script for example: I'd like the plant label parameters to change from "by style" to "by object". Manually, I have to edit each plant and click 14 times... Does anyone have an idea for changing this automatically, in batch? Thanks!
Thank you for your answer, it seems logical to me indeed. I hope that it can evolve in this direction.
Hello, Why is it that when I run a complicated command, such as generating large planted areas, vectorworks does not use all the power of the CPU? It does not exceed 11% in general, while my PC is powerful. The RAM memory is at 20%, the graphics card at 50% and the CPU remains very low, it would be more useful if it worked at 100%, right? Intel i9-11900K CPU@3.5GHZ 128Gb RAM NVIDIA Quatro RTX5000 16Gb VRAM Windows 10
2D Symbols Disappear after Ungrouping a Landscape Area
Nico_be replied to jmccain8's topic in Site Design
I can confirm that it is impossible to keep plants when unbundling a planted area. I have already reported this bug for a few years without any change. It is unbelievable! -
Hello, It is by dint of having files such as this one that I have created a "Marionette" network to transform the altitude texts into 3D points that can be used to create a DTM. First, the elevation texts must be in the same class and cleaned up a bit. After the creation of the terrain you may still have to remove some unnecessary points such as cornice heights, house walls, etc. Here is the link to try :
