Place all symbols present in the file on the drawing. Help!
Nico_be
Hallo,
Here is un script found on another site. This script place all symbol include in the file, in all folders, on the drawing.
Marvelous to create after that a tablelist and edit directly in the table.
But the script crashes at the end of the process!! :(
is somebody could take a look at it and see the error?
Pleeaase ! :crazy:
PROCEDURE ShowAllSymbols;
{?1999 Graphsoft,  Inc.}
{The traverseSymbolList procedure was developed by Craig Hollinshead.}
VAR
     numFolders, numNestedFolders, numSymbols : INTEGER;
     messageString : STRING;
     OK : BOOLEAN;
     NewPtSize : INTEGER;
     OldPtSize : INTEGER;
     SelectedObj : HANDLE;
     TheSymbolName : STRING;
     SymFolderName : STRING;
     TheSymDef : HANDLE;
     SymDef2 : HANDLE;
     ChangeAllLines : BOOLEAN;
     CurrLayer : HANDLE;
     X,Y : REAL;
     XSpacing, YSpacing : REAL;
     NumAcross : INTEGER;
     StartX,StartY : REAL;
     LayerNames : ARRAY[0..200] OF STRING;
     Index : INTEGER;
     PROCEDURE TraverseSymbol(theSym:Handle);
     VAR
             symObjClass : STRING;
             origLineWt : INTEGER;
             symName : STRING;
             symInstance : HANDLE;
             sX1,sX2,sY1,sY2 : REAL;
     BEGIN
             symName := GetSDName(theSym);
             symName := GetName(theSym);
             Symbol(symName,X,Y,0);
             symInstance := LNewObj;
             GetBBox(symInstance,sX1,sY1,sX2,sY2);
             TextFace([bold]);
             TextOrigin(sX1,sY2-1);
             BeginText;
                     symName
             EndText;
             X := X + XSpacing;
             IF (X > (StartX + (NumAcross * XSpacing))) THEN
             BEGIN
                     X := StartX;
                     Y := StartY - YSpacing;
             END;
             Message(concat('The Sym#',Num2Str(0,numSymbols),' is   -   ',symName));
     END; {PROCEDURE TraverseSymbol}
     PROCEDURE traverseSymbolList (itemHdl:HANDLE);
     BEGIN
             WHILE (itemHdl <> NIL) DO BEGIN
                     CASE GetType (itemHdl) OF
                             16:BEGIN
                                     TraverseSymbol(itemHdl);
                                     numSymbols := numSymbols + 1;
                             END;
                             92:BEGIN
                                     SymFolderName := GetName(itemHdl);
                                     numFolders := numFolders + 1;
                                     numNestedFolders := numNestedFolders + 1;
                                     LayerNames[numFolders] := SymFolderName;
                                     Layer(SymFolderName);
                                     X := StartX;
                                     Y := StartY;
                                     TraverseSymbolList (FInFolder (itemHdl));
                             END;
                     END; {CASE GetType (itemHdl)}
                     itemHdl := NextObj (itemHdl);
             END; {WHILE (itemHdl <> NIL)}
             IF numNestedFolders > 0 THEN
                     numNestedFolders := numNestedFolders - 1;
     END; {PROCEDURE traverseSymbolList}
BEGIN
{*/// Main program ///*}
     XSpacing := DistDialog('Enter Horizontal Spacing Distance:','');
     YSpacing := DistDialog('Enter Vertical Spacing Distance:','');
     NumAcross := IntDialog('Enter the number of symbols per row','');
     Message('Click on top left corner of the grid');
     GetPt(StartX,StartY);
     CurrLayer := ActLayer;
     numFolders := 0;
     numNestedFolders := 0;
     numSymbols := 0;
     X := StartX;
     Y := StartY;
     LayerNames[0] := GetLName(ActLayer);
     IF FSymDef <> NIL THEN
             TraverseSymbolList (FSymDef);
     Index := 0;
     Layer(LayerNames[index]);
     WHILE (FInLayer(ActLayer) = NIL) DO
     BEGIN
             Index := Index + 1;
     END;
     SetLayerOptions(1);
     Redraw;
     ClrMessage;
END; {PROCEDURE ShowAllSymbols}
RUN (ShowAllSymbols);
Thanks!!
jab
  • 1 month later...
