ChrisA Posted June 9, 2011 Share Posted June 9, 2011 Hi Having trouble with this one so I thought I would consult the great oracle. Why won't the walls around my doors splay the same as the windows. I can't seem to get the walls to angle back to the jamb with out the flat return on either side. I want the splay to look like my windows. (see attachment) Cheers Quote Link to comment
bcd Posted June 9, 2011 Share Posted June 9, 2011 I can't reproduce it in 2011 but I'd try a new wall style and a new door to see the results - perhaps it might reveal something. Quote Link to comment
Pat Stanford Posted June 9, 2011 Share Posted June 9, 2011 If you set the return for components to anything greater than zero, you get an extra handle that controls the wrapping point. It looks like that is what you have turned on. Just select the door and drag the wrapping point back to the edge of the jam/trim. I though you could change it in the OIP or the Door Settings dialog, but I am not finding the correct field right now. Quote Link to comment
ChrisA Posted June 10, 2011 Author Share Posted June 10, 2011 Hi Pat I'm missing something. when I select the door and try to adjust any point, the whole door splay and all moves. I'm not familiar with the wrapping points. Do i need to use another tool to select the door? I tried the 2d and 3d reshape. no luck. funny thing is that when it's in any 3d mode it looks right. Yes, I don't see a field in the OIP pallet either Quote Link to comment
Pat Stanford Posted June 10, 2011 Share Posted June 10, 2011 Can you send me the file and I will take a look? Use the email in my signature Quote Link to comment
ChrisA Posted June 10, 2011 Author Share Posted June 10, 2011 I have added a VW file, for those interested, to look at. Quote Link to comment
Pat Stanford Posted June 10, 2011 Share Posted June 10, 2011 After playing with it it appears to be a corrupted object. I can insert a new door and set the parameters and it works OK. Did this file start in VW2010 or an earlier version? Quote Link to comment
Farookey Posted June 10, 2011 Share Posted June 10, 2011 ...Same as Pat... A new door object works fine... Quote Link to comment
ChrisA Posted June 10, 2011 Author Share Posted June 10, 2011 yes it was a 2009 file. I have tried to delete the original and replace it with a new one but no luck. it appears the whole file is corrupt because I can create a new project file and it all works fine. thanks of for the help. I might have to start from scratch if I can't figure a way around this. Quote Link to comment
ChrisA Posted June 10, 2011 Author Share Posted June 10, 2011 got it, I made a new door and wall in a new file and copied it into my old drawing.that saved me a bunch of time. thanks again Quote Link to comment
