Assemblage Posted October 4, 2010 Share Posted October 4, 2010 Simple one for you Worksheet folk: I have a small worksheet which has some database info spread over a few columns, which I've then performed a column of calculations on. In the next column(s) I want to just input some numerals by hand, like text. They are standards from the Brief which I want to be seen side by side with the database info. Can I do this? Quote Link to comment
willofmaine Posted October 4, 2010 Share Posted October 4, 2010 Could you add the standards from the Brief to your Record Format(s), then report on them in the next column(s)? It seems what you want to do wouldn't work because the database sub-rows are, I think, always a function of their database header row... Quote Link to comment
Pat Stanford Posted October 4, 2010 Share Posted October 4, 2010 willofmaine is correct. The only way to put data into a database sub-row is to have it attached to a record of some type. For Plugin Objects this can be either the PIO Record (door.width) or a custom record format attached through the Data pane of the OIP. For other objects it has to be a custom record format. If you already have the custom record format then just add the fields you need. If you don't have a custom record format then create one and attach it. The formula you will then need is something like ='My Custom Record Name'.'My Custom Field Name' You will be able to enter the data either in the data pane of the OIP or in the database row. Quote Link to comment
Assemblage Posted October 5, 2010 Author Share Posted October 5, 2010 Works well - thanks Quote Link to comment
